crank case breather
Old Mar 20, 2003 | 01:16 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
crank case breather
I need some stock parts for my crank case breather assembaly, I converted to tpi from tbi and have it rigged up so itll work but I want it to look stock or at leat good. Can you get these parts at kragen or is this a dealer item? I also would like part #s if at all possible. thanks
Old Mar 20, 2003 | 02:41 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
The TPI pulls in from the PCV valve on
the drivers side VC, and supplies fresh
clean air into the passenger side VC from
the large port on the top Pside of the
throttle-body.. No real "breather" to
speak of, you can practically do it all
with emissions hose.
mike
Old Mar 20, 2003 | 02:46 PM
rezinn's Avatar
An alternative, if you feel like doing so, would be to stick a breather in the passenger side valve cover and block off the throttle body nipple with the proper cover. I saw an old hot rod corvette with an LT1 and they had done this and it looked pretty clean.
Going for the stock look could be accomplished with just emissions hose, unless you find the correct adapter to go on the valve cover like tpi cars have. Then you'd need at least one of the aluminum tubes to run it down near the runners. I doubt it's a stocking item anywhere. You may be able to make one and paint it black like the stock one, though.
Old Mar 20, 2003 | 03:14 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
yea the only thing i really need is the piece that goes into the pas. side valve cover for the hose to hook up to. you know?
Old Mar 20, 2003 | 03:31 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I'd try a junkyard. I'd bet pretty much EFI GM car in history probably uses the same piece.
Worst case though, if you're using SD, you can use a regular breather in the VC. Thats onely a problem if you have MAF. But the stock setup is cleaner looking IMO.
Old Mar 20, 2003 | 03:37 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
I dont wanna use a aftermarket breather for it just cuase of cali smog rules, but i bet your right about your assumption so I might take a little trip down to the bone yard if I cant find anything at kragens or in my garage to do the trick. thanks for the help again you guys are too good.
Old Mar 21, 2003 | 01:33 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
got all the stuff from the HELP! section at kragen I used a gm ccv gromit with the ford elbow and it works great.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
MM2Robinson
Oct 1, 2017 09:16 AM
djmarch
May 8, 2016 11:32 AM
sleprock
Sep 24, 2015 04:33 PM
