Question about injectors
Old Mar 22, 2003 | 01:10 PM
j_bonham69's Avatar
Hey i have a stock 305 TPI 89 Trans am. i want to replace the stock injectors. what Lb. injectors shoul i buy? i don't know a lot about these things so any help would be much appreciated. thanks a lot.
Old Mar 22, 2003 | 02:43 PM
88 IROC BOB's Avatar
Stock ones I believe are 19# for 305's. The 350 cars got 22# injectors.
Bob
Old Mar 22, 2003 | 04:13 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
If you are not planning to do any PROM recalibration you should stick with #19 injectors. If you are planning on doing other modifications in the future you may want to go bigger, but you must recalibrate the ECM or you will run rich.
I have #30 injectors in my 305, but it is modified and has a custom PROM that was reprogrammed a few times to get a good air/fuel ratio.
MustangBeater20
Oct 29, 2022 09:20 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
