Oil Pressure
Old Mar 22, 2003 | 01:59 PM
mess21's Avatar
Oil Pressure
what would be the normal oil psi durin idle etc for a 350 tpi
Old Mar 22, 2003 | 04:42 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Should be a minimum of 15 PSI. But the old rule of thumb is 10 psi for every 1000 rpm for proper lubrication.
Old Mar 22, 2003 | 06:42 PM
mess21's Avatar
well mine is about at the min my auto meter gauge reads under 25psi at idle how can i increase the oil pressure
Old Mar 24, 2003 | 06:56 AM
sillyiroc's Avatar
Car: 89 Iroc
Engine: 350 vortec TPI
Transmission: 95 T56
my old z28 with a 305 tbi 189,000 used to run around 10-15 psi indicated on the stock gauge. dont know how acurate the stock gauge is, it still ran smooth and never knoked. dusnt meen thats ok! you might want to try runing a heavier weight oil.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
