What is the correct TPS voltage at idle (850 rpm's)?
Old Mar 24, 2003 | 05:05 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
WHat is the correct voltage or voltage range for a 1991 Z-28 TPI 350 at say arround 750-900 rpm's? Right now mine is sitting at .47
Mike
Old Mar 24, 2003 | 09:22 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
The stock TPS setting for the throttle in the closed position (idle speed doesn't matter, that's controlled by the ECU) is .54 V.
eightsixseven
Dec 16, 2024 01:50 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
