Best chip for a 305 TPI????
Old Mar 25, 2003 | 04:06 PM
Doogie92Z28's Avatar
I have a 1992 Z28 ragtop with a stock 305 tpi. It has 76,000 miles on it. I have a full custom exhaust. I put a low temp thermo in it to make it run cooler. What is the best chip that i can get fr this motor? thanks for the help
Doug
Old Mar 25, 2003 | 04:11 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
If you put that stat in then you can go with a hypertech thermomaster its designed to work with a 160 stat but you wont notice much hp gain. The best way to go is with a custom prom burnt for your application but I doubt youll get much more out of it with those mods. I say save your money, buy a k and N and an AFPR.
Old Mar 25, 2003 | 05:03 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
custom prom
Old Mar 25, 2003 | 05:37 PM
5SIZ's Avatar
Car: 1987 IROC-Z
custom prom of course.
Old Mar 25, 2003 | 05:52 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I'd say stock.
If this guy can't even read stickies, i doubt he has any business poking around in his chip, no matter how easy it is.
Old Mar 25, 2003 | 08:32 PM
eric, SLP, and SIZ...thanks for your help. I have heard that the custom prom is good but i want to wait to do that when i build up the engine. I will talk to you guys about that later. And to Ed, you arn't much of a people person are u?
doug
Old Mar 29, 2003 | 01:39 AM
metalgod's Avatar
dude, i had an 89 formula 305 tpi, i bought a performance chip (ADS) i think, ther is a better chip out there and you can get it throught the dealer, get a chip for an 89 vette automatic with the performance axle ratio (3.07). The vette chip and the 21.6 lbs injectors made a huge difference. way more than the ADS. with the vette chip, you will have to change injectors cause the chip is calibrated for 21.6 lbs injectors instead of the 19 that are on 305's. The vette chip will run very lean if you dont put injectors in it. I found that the vette chip is more responsive to throttle input from the gas pedal than the camaro chips.VATS is a problem in 88 and later camaros. my 89 had VATS to begin with, so it worked. I am also working on moding the ECM to bypass VATS and i will get back to you on that one.
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
