problems
Old Mar 30, 2003 | 05:54 PM
screwowmer's Avatar
problems
I have just put a 87 350 TPI into my s10 with a painless wiring harness and it starts but wont idle runs for 2-3 second and thats it..
please help!!!
Old Mar 30, 2003 | 10:20 PM
Swapmaster's Avatar
What did you use for a fuel pump?
Old Mar 30, 2003 | 11:51 PM
rezinn's Avatar
Try to start it without the MAF sensor connected.
Old Mar 31, 2003 | 06:43 PM
screwowmer's Avatar
I used a stock IROC fuel pump for the 350
Old Mar 31, 2003 | 07:10 PM
screwowmer's Avatar
unplugged MAF and it runs for a couple seconds longer bu thats it, if you the MAF plugged it will run while you have your foot on the gas a bit.
Old Mar 31, 2003 | 07:39 PM
rezinn's Avatar
I think the most important thing to do is verify that the engine is in proper timing. Try putting it between 6-8 degrees btdc. Have you reset the throttle position sensor to .54 volts? You could also try disconnecting the idle air control valve and starting it. Just a few guesses. Lots of things can cause that sort of starting and dying, or a combination of little things.
Make sure all vacuum hoses are in place as well, you don't want leaks before the MAF/throttle body. There are a few hoses at the rear of the plenum that could leak, as well as a sensor located in the bottom above the egr, or a couple hoses in the throttle body. Runner leaks could also cause this if they are severe enough.
Old Mar 31, 2003 | 10:03 PM
Swapmaster's Avatar
Can you check fuel pressure? With a guage hooked up, start it and make sure the pressure don't drop off as it dies.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
