What is the factory Timing and Degree of my 89 formula
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
It should be 6º BTDC.
There should be a sticker under the hood with this info also.
Be sure to disconnect the Tan-Black wire while setting the base timing.
The simple things always get us.... did you verify your firing order on the cap? Making sure that you replaced the #1 plug wire in the same spot? If the #1 wire is on the wrong terminal, your timing will be WAAAAAAYYYY off.
Small Block Chevrolet firing order is:
1 8 4 3 6 5 7 2
1 8 4 3 6 5 7 2
theshackle
Sep 17, 2020 08:26 AM
