My video.....
Old Apr 9, 2003 | 03:09 PM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
My video.....
Here is a video of my car if your interested. Thought I would share it with you all.
I was scanning the car during this takout and I was only at 60% throttle according to the Ease Software. I did not go full WOT because I get pinging past 1/2 throttle without the "Rocket Fuel" ( A mixture of Toluene, ATF ) for a resulting octane of 110+.
You can see the car kick sideways about 30ft up the road, and this was with 10" new M/T slicks.
Expecting way low 11's or even high 10s out of it.
Enjoy the video....
http://www.megapathdsl.net/~mimsk/Movies/Burn.mov
Old Apr 9, 2003 | 03:26 PM
tpi_roc's Avatar
Not tpi related, AAAAAAAAND you used quicktime... I should lock this but can't bring myself to do it out of respect
nice goods man
Old Apr 9, 2003 | 03:36 PM
ski_dwn_it's Avatar
tpi_roc,
Sorry did not mean to break any rules......
Thought it was TPI related since its a TPI car......Sorry again, but thanks for leaving it open. Alot of work went into the beast this winter and just wanted to share it. Again sorry if I caused any problems and thanks for leaving it open!
:cheeers
Old Apr 9, 2003 | 03:37 PM
tpi_roc's Avatar
I was just playin man relax
Job well done that things a monster
Old Apr 9, 2003 | 03:39 PM
ski_dwn_it's Avatar
Got me
Old Apr 9, 2003 | 05:26 PM
OMINOUS_87's Avatar
ski_dwn_it
That sure is a bunch of compression! Please spill all the knowledge you have of homemade octane boosters, it would be much appreciated.
Old Apr 9, 2003 | 05:48 PM
ski_dwn_it's Avatar
Here is it in the nutshell, you have to find what combo you need. Basically you need the least amount for no detonaion, any more and it can hurt performance.
http://www.gnttype.org/techarea/misc/octanebooster.html
Old Apr 9, 2003 | 07:48 PM
OMINOUS_87's Avatar
Nifty! What % do you run to eliminate ping at WOT?
Old Apr 9, 2003 | 08:50 PM
ski_dwn_it's Avatar
Not real sure to be 100% honest with you. I figuring it will not take all that much ~96-100 octane should do it. I am meeting corkvette1 tomoorow outside of pittsburgh to pick up both race gas and the 5 gal of toluene. I am gonna try the race gas first, and see how that reacts and then mix up small amounts with the toluene to find you what works the best. Its gonna be sorta trial and error.
I am guessing that I won't need a whole lot more octane to keep it from pinging. The car pings much less with 94 then 93. With 93 I can't even get on it at all. I will keep you posted.
Old Apr 9, 2003 | 09:32 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Sweet vid. Sweet car.
-Schultzy
Old Apr 13, 2003 | 02:46 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Hey what are you doing over here.
Old Apr 13, 2003 | 04:33 PM
OMINOUS_87's Avatar
Thanks for keeping the loop open! Oh my is 93 all you can get!!! I am here in AZ and stuck tied to the California laws on fuel and the best we can get out here is 91, pisses me off. I got stuck plugging in 12cc dishes into my new 383 Vs. flat tops. Oh well 10.25 is still pleanty enough for the street.
Old Apr 14, 2003 | 02:07 AM
OMINOUS_87's Avatar
Much congrats on the times, saw em on the vette forum!!!! That is fu__in flyin, with the old 165 might I ad. I have read of your battle against the 165 from your first burn till your latest pass. I am modding an ARAP right now for my SR-383. Could you give a brief description on where you ended up with your chip? Did you end up with an ARAP or go to 32b? What parameters did you emphasize on modding out to get your fuel on? All info would be very much appreciated as I hope to get a decent data log with my first few burns and definitely dont want to ever spend the time to burn hundreds of SD chips.
91 camaro racer
Jul 28, 2014 09:36 PM
adictomusic
Mar 18, 2014 04:32 AM
entrig00
European Region
May 27, 2004 02:21 PM
HI92Z28
Jul 7, 2003 03:58 AM
