Code 13 ? ? ?
Old Apr 9, 2003 | 03:52 PM
Cliff92Z's Avatar
Car: 1992 Z28
Code 13 ? ? ?
I'm getting a code 13:
-- Oxygen sensor signal stays lean during warm engine cruise
Any ideas on how to correct it?
Old Apr 9, 2003 | 06:19 PM
ULTM8Z's Avatar
Check your fuel delivery system starting with the easiest steps first:
Check your fuel pressure at that speed- you'll need a pressure gauge that you can see while driving. Low pressure could indicate a bad fuel pump or filter.
Run some fuel system cleaner.
Replace the fuel filter.
Run a fuel delivery test on the pump- I believe the procedure is outlined in your shop manual.
Next check your sensors- O2, coolant temp, MAT, MAP, etc. If you have a scanner, check to make sure you're getting reasonable values for the sensor outputs. If you don't it's probably a good idea to get one.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
