code 33
Old Apr 11, 2003 | 04:54 PM
f0rmula350's Avatar
code 33
it wont go away, i start the car its fine, when i start driving, it comes on and the car runs like ****, its something to do witht the maf sensor, and there is a new one on there.
Old Apr 11, 2003 | 06:30 PM
tpi_roc's Avatar
check the maf relays, and wiring for them and the maf
Old Apr 12, 2003 | 08:31 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I will bet you that it is not the relays or wiring!!!!
Under what driving conditions does the ECM set the 33 code???
Be very specific.
Old Apr 13, 2003 | 01:33 AM
f0rmula350's Avatar
wheni start it, it idles great, but when i start drivin it the light comes on. hope this helps
chris
Old Apr 14, 2003 | 12:07 AM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
Does is try and stall at lights and when ever you are stopped. I had a similar problem, and it turned out the be the MAF burnoff relay.
Old Apr 14, 2003 | 08:54 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Be very specific.
For the past two years it has always been the wiring or the relays. What makes you think that it isn't.
Do a search to find how to check all of the wiring, and then let us know what you get. I would change the burnoff relay first, then if that doesn't work, check all of the wiring and relays.
Old Apr 14, 2003 | 08:27 PM
f0rmula350's Avatar
were is the burnoff relay at? and how much are they?
Old Apr 14, 2003 | 08:34 PM
jgifford's Avatar
Car: 1986 Z28
I hope this helps a little....
Old Apr 14, 2003 | 08:54 PM
f0rmula350's Avatar
awsome thanks!!!!
Old Apr 14, 2003 | 08:59 PM
f0rmula350's Avatar
what is the year of your car??
Old Apr 14, 2003 | 09:48 PM
jgifford's Avatar
Car: 1986 Z28
I have an 86 z
Old Apr 16, 2003 | 12:41 PM
SARswmr's Avatar
I'm having the same code with a 2 month old Wells MAF, but my code comes on after about 10 seconds of starting the car. Turn it off for a minute or so and it is not there when your restart the car, but 10 seconds later there it is. I'm running out of ideas.
Anyone?
Tim
Old Apr 16, 2003 | 12:47 PM
jgifford's Avatar
Car: 1986 Z28
SAR,
If you are having pretty much the same symptoms as above, you need to look at both MAF and Burnoff relays. If one or the other is not working, that code will pop up.
Old Apr 16, 2003 | 02:21 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
This could only be a few things..
MAF Burnoff relay
MAF Power relay
MAF itself
MAF wiring to ECM
MAF wiring to relays
My wires got toasted by the side of the radiator.. check that..
Old Apr 16, 2003 | 09:09 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Maroon-IROC-Z:
Many of us on this board for the last 5 years (some of these members have left the board) has had issues with the 33 error code. I had this problem (in around 1997 to 1998) and did the usual recommended stuff, change the MAF burnoff relay, change the MAF power relay, bought a new MAF (oach!), reset the TPS voltage at idle, etc, etc. It got to the point that I could go out to drive the car and I could predict when the code would show up. It was a specific set of driving conditions that can trigger the 33 code. In some cases, it could be one the relays, but in most cases that I have seen on this board, it was not the relays or the wiring.
My statement that I made above is based on fact, a very expensive fact for me having purchased all I did before I determined that a specific set of driving conditions was setting off the 33 code.
You can also get rid of the 33 code for good by having a custom Eprom chip burned for your car. This is the only sure fire way that I know of.
Old Apr 16, 2003 | 10:13 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
I work for firestone and in the past we have always bought wells remanufactured mafs and 90% of the time the cars come back and the maf has gone out again. before i worked a firestone i bought a maf form i 88iroc and just after the warranty was out the maf took a ****.
NEVER NEVER EVER EVER BUY A WELLS MAF
ALWAYS GO TO DEALERSHIP
Old Apr 17, 2003 | 07:30 AM
f0rmula350's Avatar
i replaced, maf burnoff relay, power relay and the wiring harness for the burnoff relay, myne was shot to ****, the next thing im replacing is the wiring to the maf.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
