runner's or base first
Old Apr 16, 2003 | 02:45 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
What would give me a bigger power increase, the SLP runner's or the Accell base. Sorry if this is a question that has been asked a million times
Old Apr 16, 2003 | 05:52 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Start with the runners. They are cheaper than the base, and can be worked on further when you decide to get the base.
Old Apr 17, 2003 | 02:55 AM
age's Avatar
age
Car: 1992 Z28 1LE
I agree.. get the runners first. You wouldn't be able to do much with the base while using the stock runners. My friend and I measured the runner ports on the Edlebrock base when I first got it, and they match the stock runner size.
Old Apr 17, 2003 | 03:13 AM
85TPI400's Avatar
I would say the opposite of eveyone thus far, SLP runners with a stock base (unless fully ported or siamesed) will not give you near the performance increase you would get with an accel base with stock runners. The design of the stock base is what causes the system to drop horsepower after 4500 rpm, not the runners, an Accel base is capable of making more power across the entire rpm range and will usually peak after 4500 RPM. I hope that there are people that will back me with this statement!
Good luck!
Old Apr 17, 2003 | 07:17 AM
Car: 91Z
Thank's for the reply's everyone, I was thinking of doing the base first because I may go for the super ram, but I am realy not sure yet. It's all about the money isnt it!!
Old Apr 17, 2003 | 08:14 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Replace the base, it is the weakest link.
Old Apr 17, 2003 | 08:29 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Just wait until you can afford both. Neither will have a large impact without the other, and if you're going to go through all that work to change the base, why not put the new runners on at the same time?
Old Apr 17, 2003 | 08:30 AM
f0rmula350's Avatar
yeh go with the base first, start at the bottom and work your way up.
Old Apr 17, 2003 | 08:37 AM
Car: 91Z
I find that the runner's are easy to change. It's the base that takes a little more time.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
bjpotter
Oct 4, 2015 07:48 PM
Royal_Z
Sep 30, 2015 08:45 PM
