Plenum vaccuum line connection...
Old Apr 13, 2003 | 09:01 AM
Germ's Avatar
Quick question: There are two vaccuum line connections at the back passenger side of the plenum. The smaller is for the line to the fuel pressure regulator, whats the larger (further rearward) one for?
Old Apr 13, 2003 | 09:37 AM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
IIRC, it goes to something related to the smog system. Either the a.i.r. divertor box or the charcoal canister.
Old Apr 14, 2003 | 11:18 PM
BOTTLEDZ28's Avatar
Transmission: A4
Is it the same plenum that has always been on your car? I ask this because I have a speed density setup and I also have 2 fittings and the other one you mention is used for the MAP sensor on mine.
Old Apr 15, 2003 | 11:12 AM
Germ's Avatar
Yep same plenum since '87, but its a MAF car, so I'd guess thats the difference.
Old Apr 15, 2003 | 11:46 AM
Bruce89TA's Avatar
Car: 89 Firebird T/A
Mine feeds the heater controls and the cruise control as well as the vacuum resevoir on the driver's side fender.
with the supercharger, it also feeds the boost gauge, the fuel management system and the diverter valve.
Old Apr 20, 2003 | 08:03 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Here you go, this should clear up the confusion.
Attached Thumbnails Plenum vaccuum line connection...-1985-89_f_body_tpi_vacuum_lines.jpg
tyeo098
Nov 30, 2015 06:27 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
85 Jimmy
Sep 30, 2015 07:56 AM
TBRays98
Sep 6, 2015 05:05 PM
