Which heads with this set-up...
Old Apr 14, 2003 | 01:49 PM
CETATornado's Avatar
I did try a search for this and didn't find anything that would really answer my question, so...
I'm currently trying to figure out what heads I should get for my Camaro. It'll be a 305 TPI with all the basic mods (a lot of handling/suspension mods, free mods, full exhaust, etc.), and I've decided to go with the ZZ4 cam. What would be a good choice for the heads? I want something with some good improvement in both hp and torque; the low-mid rpm range is more important for me. What kind of performance gains can I expect to see with these?
Old Apr 14, 2003 | 06:27 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
check out the world torquer heads, they make 58cc chamber ones that will be cast iron and will provide much much better flow and would get u a large gain with the cam, plus will be cheap, about 320 each
Old Apr 14, 2003 | 06:32 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Re: Which heads with this set-up...
You basically have 3 main choices of heads for the 305
1. SR Torquers
2. GM Aluminum L98
3. GM Vortec
I have the L98s and love them a lot.
As for the cam, what are the specs for the ZZ4 cam? I think you could go with a bit more.
RMK
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
