Engine Overheating
Engine Overheating
I could really use some help with this one. The engine is running hot to the point to where coolant is boiling in the overflow. We have changed the thermostat, a couple of sensors (not sure which ones), and flushed the radiator twice. I have run out of ideas and would appreciate any help I can get. The engine is a 5.0 TPI. Thanks in advance.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Two things may be causing this, well Maybe 3.
1st.....and the worse case, is the Heater core may be plugged.. Once the vehicle has warmed up a bit touch both hoses to the core to see if they are equally hot.
2nd.....and not too bad, is the lower rad house may be collapsing, causing the restriction of flow.
3rd.....You have a air lock in the system, try loosening the rad cap half way off, let the car run for a considerable amount of time..so it gets to full running temp. This may help release and air pocket.
Opp make it 4 things..
Your water pump may be going for a crap, but I would check these other reasons first.
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
86 do you notice a loss of power in the engine at all? any hard starting? (when the car is warm)
allright well if none of the other stuff works, I would check your timing, it it's too far advanced, it can cause boil over at any speed, and loss of power as well... give that a shot if nothing else works... it should be around 6 degrees BTDC.
