What bolt size/thread for the TPS?
Old Apr 20, 2003 | 08:50 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
I need to know what bolt size/thread the bolts for the TPS are, because when I was going to replace the throttle body I realized that one of the TPS bolts was bad, the threads were damaged at the end of the bolt....
If there's a part number for these bolts it'd be very good to know since I am afraid that they might be not-so-common in Europe where I live.
Old Apr 20, 2003 | 09:02 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Unfortunately, they're not really an easy to find metric OR standard (my experience anyway). I broke one a while ago, and wound up going to the junkyard and taking one off a 2.8L V6 F-body. They use the same basic TPS, and the screw is exactly the same.
Old Apr 20, 2003 | 11:08 PM
ZaphodB's Avatar
Okay, that means that I am either heading to the junkyard or the machine shop to have the holes re-tapped for some more normal bolts....
Old Apr 21, 2003 | 09:18 AM
ZaphodB's Avatar
Is the bolt size the same on TBI as on the TPI?
Reason I wanna know is that I am more likely to find TBI cars in my local junkyards since there are not many F-bodys around here - Especially not in the junkyards.... And I belive the same TPS is used on the TBI on Chevy Vans for example?
But I a considering have the TPS holes machined to fit standard M5's instead of hunting for M4.5 bolts...
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
