Combos for 12.50...
Old Apr 17, 2003 | 10:07 PM
BadBowtie88's Avatar
Combos for 12.50...
Everyone running 12.50 or better post your combo's here. Just looking for some ideas for my rebuild. I'd like to run at least low 12's on motor, so let's have it.
Old Apr 19, 2003 | 05:20 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
12.18 & 112.5mph here
But there's no tuned port involved. so i dunno if you even want the rest.
if your interested. it's a vortec headed 355, performer rpm intake, 780 holley, 10.7 compression Comp XE 274 cam. 700R, 3300stall converter. 3.73 gears. 26x9.5x16 cheaters
Nothing fancy, she just gets the job done.
Old Apr 19, 2003 | 08:01 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Check the sig. 12.3 @ 109.5 MPH with no tuning.
Old Apr 20, 2003 | 01:55 PM
The reason I put this post under TPI, I was trying to get fuel injected combos, wasn't sure where to put it. Sorry I should have posted that. Thanks for the input so far, anyone else?
Old Apr 20, 2003 | 05:49 PM
smithtc's Avatar
BuckeyeRoc,
What do you mean by "not tuning" ?
Stock Chip? Fuel pressure?
Do you still use MAF system?
Old Apr 20, 2003 | 08:58 PM
BuckeyeROC's Avatar
Originally posted by smithtc
BuckeyeRoc,
Fuel pressure is set around 50 psi, but not tuned or tested at different pressures. I still use stock MAF system w/ a homemade PROM with the ARAP.bin. Only changes to the ARAP.bin are a 750 rpm idle and 24# injectors.
So basically, everything was bolted together and I used a ARAP.bin with just a change in idle and a change for my injectors. I do plan to get this thing dyno tuned.
Old Apr 21, 2003 | 10:29 AM
Ragtop89's Avatar
I running a similar engine set-up to BuckeyeROCs.
355 w/Superram and AFR190s.
I'm running a XE282HR cam and I'm using Anetheses' APYP bin for 5-speed cars.
I have yet to hit the track to get some hard #s but my butt-dyno says I'm very happy right now.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
