With a fuel regulater do i still need 350 injectors?
Old Apr 21, 2003 | 05:41 AM
sst's Avatar
sst
Hi all I have 89 T/A with a gm goodwrench 350 engine.It originally had the 305 tpi engine, The guy i bought the car from had the 305 injectors put on the 350. He had a fuel regulater put on also.My question is can you adjust the fuel regulater higher to match the 350 injector pressure?Do i need to buy 350 fuel injectores?Any info would be apprieciated!
Old Apr 21, 2003 | 06:03 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The fuel pressures are the same weather it's a 305 or 350.
What you really need is a set of 350 injectors, they are rated at 22 lbs. The 305 injectors are rated at 19 lbs.
If all you have is 305 injectors and can't get the right ones you could swap to an adjustable fuel pressure regulator and increase the fuel pressure to compensate.
Old Apr 23, 2003 | 08:58 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
If you can run 58psi fuel pressure on the 19#/hr injectors, you will flow 22#/hr,, same as stock 350 stuff.
Old Apr 23, 2003 | 11:02 PM
5SIZ's Avatar
Car: 1987 IROC-Z
hahaha
if you would flow 58 psi on your injectors you would need a new fuel pump every week.
max fuel pressure before the fuel pump will crap out prematurly is 50 psi and thats eging it, unless you have an aftermarket hi flow pump.
Old Apr 23, 2003 | 11:22 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
In a MAF car like yours, it comes down to this. The injectors have to match the chip. Engine size doesn't matter. If it has teh stock 305 chip, it's set for 19s, so keep them. If it's a 350 chip, it's set for 22s and you should swicth.
Old Apr 23, 2003 | 11:34 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Or you could get the 22# injectors and reprogram your computer.
Old Apr 24, 2003 | 09:21 AM
sst's Avatar
sst
Thanks for the info! The guy i bought it from supposedly had the 350 chip put in. It still has the 305 injectors and runs good.Is there a way to tell if you have the 350 chip?
Old Apr 24, 2003 | 12:41 PM
Ed Maher's Avatar
Car: 04 GTO
Easy to tell what chip it has. Just drop the ECM from the passenger side dash, take off the wondow and look at the chip. It'll have a 4 letter code on it. Search on that code or post here and you'll know what it is.
Old Apr 24, 2003 | 06:59 PM
sst's Avatar
sst
Thanks fotr the info!
MustangBeater20
Oct 29, 2022 09:20 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Firechicken86
Aug 12, 2015 10:07 PM
