84 camaro NEED HELP
Old Apr 25, 2003 | 11:48 PM
matt10101's Avatar
84 camaro NEED HELP
ok this is my first ever post on a message board....EVER...but i need help i just got my 86 z28 and am looking for ways to make it faster..i heard tpi would be the way to go but is there a way i can add it to my camaro....i also have just put in a 350 so i just need to know if it will line up or whatever... thanks alot
Old Apr 26, 2003 | 12:54 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You can add TPI to your car. Almost any 1982-1992 part Camaro or Firebird will work in any of the above mentioned vehicles. TPI is great for low end torque. However it leaves a bit to be desired in stock form. I love mine but you have to spend the bucks to do what you can do with a carb. Trouble shooting it sucks too.
If your new to TPI or Fuel Injection in general TPI is a complicated thing to learn. I have had to learn about it the hard way.
If I were you I would keep the carb. First mod should be headers and exhaust. Then maybe cam then heads and so fourth.
Old Apr 26, 2003 | 11:15 AM
matt10101's Avatar
thanks alot i think ill just do that and read up some more about diff fuel injections before i jump into it thanks again
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
