Power loss... I don't think it's in my head.
Old Apr 27, 2003 | 06:59 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I'm experiencing a problem. The car over the past couple weeks seems to not be as powerful as it was when I first got it running. (it's L98) Not that the car isn't fast, it just seems that it's lagging. For example, when I got the car running right, I would go at WOT and the car would pull and pull and pull... now, at WOT the car still accelerates strong, but not like it did. I checked my fuel pressure, it's good. I checked the timing, it's sitting at 7 or 8 degrees BTDC. I know the factory setting is 6, would this be causing that much of a problem?
All ignition parts, etc. are new. (plugs wires cap rotor etc.)
any insight would be appreciated.
Old Apr 27, 2003 | 07:55 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Seriously, run the car on a gtech or at the track. I do not trust the accuracy of your butt dyno.
Old Apr 27, 2003 | 08:04 PM
Where do I find a Gtech? That's another thing I'm thinkin too, it may just be in my head.
Old Apr 28, 2003 | 12:26 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Track times or dynos don't lie... check your car out!
Old Apr 28, 2003 | 01:27 AM
You're right there... my only problem is that I know of NONE in my area. I've looked . I'll keep searching though.
Old Apr 28, 2003 | 08:09 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You might try increasing your timing. I know my car was fond of 10 degrees. It once went much higher than that and didn't have a problem. But I backed it down to be on the safe side. That and it got crappy fuel economy.
Old Apr 29, 2003 | 12:22 AM
I'll have to give that a shot. My timing light's on the fritz, so I'll have to wait. I heard another person tell me their TPI liked 10 degrees as well... coincidence? I think not.
MustangBeater20
Oct 29, 2022 09:20 PM
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
gta90
Sep 15, 2015 04:00 PM
InfinityShade
Aug 22, 2015 08:00 PM
