Vortec Head Kit.....
Old Apr 30, 2003 | 01:09 PM
KYL98's Avatar
Car: 1991 Z28
I just ordered the Vortec Head kit with the TPI Base from Scroggin-Dickey. IT should be here by the end of the week. I also ordered the LT4 Hot cam.....I decided to go all out finally....it should still be ok to drive everday, dont you think? Im also getting the Mufflex Y connector for the Hooker LT's I ordered.....Just thought Id share with you guys....wish me luck....now if I just knew how to burn my PROM...
Old Apr 30, 2003 | 03:10 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Yes, you probably will need ALOT of PROM tuning! The stock chip would barely even start the car, let alone keep it running! I'm on chip #22 and it's running ALOT better, but I still have a long way to go before it's perfect or close to. However, you do have it a little easier because you are running smaller injectors and a smaller cam. Good luck!
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
