Help: 165-to-730 VATS question...
Old May 1, 2003 | 02:03 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
Howdy all, I'm planning on doing this swap so I can 6 my MAF plumbing but have a big question.
Am I going to be able to start my car after the swap without the VATS ignition hardware? I don't want to get it all in, only to find out the ECM isn't getting a required signal from the VATS input. I know I can disable it in the prom but I'm not into that yet as I just blew all my money on this swap. Is there any way I can physically disable this with a resistor or something in the interim?
Thanks...:hail:
Old May 4, 2003 | 07:04 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Sure, you can do the "ol resistor trick" but the problem is, you'll need to install a PassKey module to interpret the resistor and send the signal to the ECM. Your only other option is to have the VATS disabled in the PROM.
Old May 4, 2003 | 07:21 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I can make you a chip with the VATS disabled, you'll just need to either remove your stock prom from the memcal or get a Moates Adaptor.
Old May 5, 2003 | 03:02 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
how much? Like I said I already blew all my money on the ECM and hardware...
Old May 5, 2003 | 03:07 PM
Zepher's Avatar
Sent ya a PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
AmorgetRS
Sep 28, 2015 09:33 PM
Winchester1094
Sep 15, 2015 09:48 AM
