a 58mm TB for an 85-88 car on my 92?
Old May 3, 2003 | 06:02 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have a chance to get a cheap 58mm TB for an 85-88 car and I need to know what is special that might make it hard to put on my 92? In other words not just "what is different?" but " does it really matter, what can I do about it?"
Old May 3, 2003 | 08:04 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I know the throttle cable is different setup but you can get a cable for a 85 to 88 and it will work great. That is the only thing I can think of.
Old May 3, 2003 | 08:14 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
if I have to buy a bunch of cables and stuff then it doesnt seem like such a great deal this guy is selling.
Old May 4, 2003 | 08:29 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
what is different on the cables? Im only running throttle and TV (tranny). I never realized those were different, anyone?
Old May 4, 2003 | 10:24 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Yeah, the 85-88 throttle cable is held on the TB arm with a clip. Sorta like the cruise control cable. Where as the 89-92 throttle cable, you just route the end of it into the slot on the TB arm. The TV cable is the same, you'll just need to change the throttle cable.
You can get a throttle cable for around 20-25 bucks and it's easy to change.
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
