Gas cap
Old May 10, 2003 | 05:31 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Gas cap
This morning I discovered that the Stant locking gas cap on my '88 TPI Bird is vented!!(It can suck air in ,but can't push it out)
Some years ago I took it of from my old Malibu,it did fit,so I didn't pay much atention to it.
I refitted the original,not vented,not locking cap back on now.
But here's my question:what can happen when using a vented gas cap,when it's not supposed to vent?
Old May 10, 2003 | 01:52 PM
Old May 10, 2003 | 06:48 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
YOU WANT THE VENTED ONE!!!! I had a non vented one on my camaro and when the engine uses fuel it needs air in to replace the fuel. I learned the hard way and left the non vented one on and it had so much vacumme that it collapased the fuel tank making it smaller. I had to replace the tank, sender since it bent that up as well after 500.00 later it is all fixed.
Old May 10, 2003 | 07:01 PM
MasterEvilAce's Avatar
Really? hmm.. Where are the vents located? on the top near the handle? are they very visible? I have to see if the cap on the car now is vented...
Old May 11, 2003 | 03:07 AM
well,the vent holes are very well vissable,when you take the cap of,they are in the middle of the dome,3 or 4.
What I did to be sure(not tasty,though!) put my mouth on the inside of it,try to blow,wouldn't,try to suck,would!
But I thought 3-gens TPI's had a kind of vent valve on the tank somewhere,so the cap shouldn't be vented(like the original that was on the car)!
Anyone else thoughts on this?
Old May 11, 2003 | 03:07 PM
AaronIROCZ's Avatar
Well it may be but either way if it does have another vent system then mine is not working so all of mine are vented because I dont want to go through that again.
Old May 12, 2003 | 01:17 PM
Last sunday at a large USA car meeting,I spoke to a GM parts seller,he told me the only thing that happens when using a vented gascap is that this coal canister in front of the engine doesn't work,so I put the vented,locking cap back on,emission inspections are very easy overhere!
I pass it even without a cat!!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
