Stock injector HP?
Old May 12, 2003 | 03:47 AM
Kiwi-85IROC's Avatar
Will 305 injectors supply enough?
G'day...Can anyone tell me at what point (HP wise) do the stock injectors run out of puff on a 305 TPI motor?
Old May 12, 2003 | 08:08 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
They don't, its the stock 305 TPI motor.
Old May 12, 2003 | 06:01 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Really looks like it
"World Heads, Comp Cams XE262,Hookers,AFPR,Ported & port matched Plenum/intake & heads,Transgo kit,Corvette servo,2.73 posi, 100 shot of juice,60k original car."
From what I have read 305 TPI injectors are rated at 18.4 lbs @ 34 psi
18.4 lb injectors can support up to 295hp
19.01 lb injectors can support up to 304hp
Robert
Old May 13, 2003 | 01:35 AM
Roger that...so with the Nitrous being hooked up tomorrow, I'd say that I'll be running out of injector pulse to feed it and keep it from leaning out?
Old May 13, 2003 | 04:11 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
I would have thought that you would be running a wet kit and adding extra fuel from the nitrous nozzle along with the nitrous as opposed to adding extra fuel via the injectors? You would simply have the fuel line plumbed into the schrader valve on the fuel rail for supply.
What kit do you have?
Old May 13, 2003 | 05:02 AM
I've got my hands on a Venom system that increases the injectors
pulse..system is aimed at batch fire injection that the 3rd Gen TPI motors have.
Old May 13, 2003 | 08:35 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I have heard that the Venom kits are good. I also heard that they did things a bit differently. Where did you get it from? How much does it go for?
I am interested in why it would be a better kit than your average system.
Old May 13, 2003 | 02:12 PM
From what I understand..if it goes lean it shuts off the Nitrous and seeing as I'm only going to be running a 100 shot I thought it was a safe system.
Old May 16, 2003 | 03:50 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
I've never heard of this kit before. Post over on the power adder board and they will be able to give you the info you need.
I'm interested to hear what they have to say on the subject.
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
z28_AJ
Aug 27, 2015 08:59 PM
ezobens
Aug 19, 2015 10:29 PM
