question about info on a website
Old May 13, 2003 | 09:09 PM
88gtagearhead's Avatar
http://www.fuelinjection.com/portinj.html
"The 57L injector is sized to deliver approximately 4.83 milligrams of fuel with a 2.5 millisecond pulse or 23.92 lbs per hr at approximately 43.5 PSI."
The quote can be found near the bottom of the page under 'fuel injectors'
Is this true, because i always thought it was 22 lbs?
Old May 13, 2003 | 10:12 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
they are 22# they flow 22# @ 37 psi with the vaccum on. when you floor it, vacuum drops to 0 and pressure goes to 43.5 and jumps to 24# that's why you get an adjustable fuel pressure regulator. that way you can raise the pressure to gain more flow out of them. to a point.
Old May 14, 2003 | 05:22 PM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
i thought the same thing as gearhead, thanks for clearing that up
chazman
Aug 28, 2018 03:25 PM
Caspar
Jun 19, 2016 11:19 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
