TPI Swap just finished..ENGINE WON'T CRANK...HELP
Old May 13, 2003 | 11:04 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I Just finished a tuned port swap and tried to crank the engine over but it wouldn't crank.... I had a chip burned without the VATS in it so it cant be the vats..... I have power to the ignition but i don't have power to the prple wire on the starter nor to the relay that the purple wire plugs into on the terminal on the fire wall on the drivers side. I took all the relays off the car i got the tuned port system off of, the only thing i had to change in that terminal was the plug that goes to the tranny since mine is manual and the donor car was automatic.Also i noticed the orange "SECURITY" light in the instrument panel stays lit and won't go off..... This is driving me insane anyone have any suggestions?
Old May 14, 2003 | 06:36 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Strange...usually if the security light stays on it is a VATS issue. Are you sure you had vats bypassed in the chip? Maybe you can try manually bypassing VATS with a resistor, this way you can be totally sure it is or isn't vats.
Old May 14, 2003 | 08:58 AM
91blackgta's Avatar
That really sounds like VATS to me. Mine did the same thing when the vats went out. I wasn't getting power to the small purple wire going to the starter silenoid. You might want to try bypassing it. Check out the tech section. Just a thought.
Old May 14, 2003 | 09:07 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
VATs does 2 things. It sends a signal to the ECM to allow it to use the injectors, and it enables a relay that allows the starter to engage.
The only way around the starter relay is to bypass it, the chip has nothing to do with that.
If that's not the problem, then apparently you did something else to that circuit while you were doing the swap. Nothing we can do to help you there, just a matter of tracing circuits.
Old May 15, 2003 | 06:06 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Axle/Gears: 7.625 10 bolt/3.73s
It is definately VATS, the orange light goes out if it is working properly. Try spraying contact cleaner on the key and in the keyhole. This fixed my VATS problem I had just a few days ago.
gta90
Sep 15, 2015 04:00 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
