Disconnect this?
Old May 14, 2003 | 05:59 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Disconnect this?
I was wondering if I want to fool around and put on a manifold and carb instead of my TPI just to see what it does, can I just disconnect the sensors and leave them hang for now. I know I would have a different AFPR for the carb. But would disconnecting these things screw up the computer? Thanks.
Old May 14, 2003 | 06:49 PM
1988irocz350's Avatar
uhh there is a lot more to it then that. Unfortunitly I dont remember right now what all has to be changed, I know the fuel pump is one of them.
Run a search in the forum, i'm sure there is a thread somewhere with someone doing this and the details on what you need to do.
Old May 14, 2003 | 07:38 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
don't need to change the fuel pump. just get the mallory 4309 regulator. has a return port. if you put a manifold and carb on, you won't need the computer. you will need to get a non-computer controlled distributor. the ony thing the ECM controls is engine stuff. and depending on year of car, the speedo.
Old May 15, 2003 | 12:06 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Ok
The speedo is mechanical on mine. So the distributor and I can just leave that stuff unhooked. Thanks guys I just might fool around with it.
xodus2002
Jul 17, 2020 09:08 AM
gta892000
Aug 11, 2019 11:16 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
