Can't get 1991-Z28's Car to run right, Any suggestions?
Old May 14, 2003 | 08:48 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
We set the timing at about 8 degrees. The fuel pressure is set at 44psi. This thing is pulling 12 inchs of vaccumn at idle and even my own 388 pulls 16 inchs at idle. I change the plugs on it switched out the ignition coil. I've reset the valves incase they were not set properly even though its a crate motor and you should have to. I played around with the PROM, and when i try to give it more fuel in the VE tables, it just runs terrible. The plug readings are jet white, which means its running way too lean, but it doesn't like to run any richer than it is now. The car is extremely jerky fuel if added to it in the PROM. What other suggestions to run on the checklist to get this thing going properly before nationals?
Old May 16, 2003 | 01:31 AM
rockind78's Avatar
what else have you tried?
Old May 16, 2003 | 01:36 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
Now i'm going back to the basics and checking to make sure the firing order is correct. I assummed that Third Gen Resource would atleast have that correct but then again assumptions often lead to something going wrong. Thats next on the check list.
Old May 16, 2003 | 10:23 PM
rockind78's Avatar
I take it you have already utilized some sort of scan tool?
Old May 16, 2003 | 11:22 PM
tjrh522's Avatar
running way lean....check for vacuum leak...check all areas..
try spraying some starting fluid in different areas and see if the RPM increases...that would be a tell tale sign.
Old May 16, 2003 | 11:30 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i agree...the motor has enough fuel or it wouldnt run crappy when more added..that and the fact u only have 12 inches of vacuum, id say that u have a vaccum leak..and my buddy tjrh522
is dead nuts in the way to check for it..
Old May 17, 2003 | 01:30 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
no vacuum leaks, i sprayed all around the intake and nothing happens.
Old May 17, 2003 | 04:18 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Did you check all the vaccum lines? Some of them are hidden well.
David
Old May 18, 2003 | 01:03 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
yep and replaced all of the vaccumn lines to make sure the old ones weren't at fault.
Old May 18, 2003 | 01:21 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Your "sig" had nothing about the cam specs. If the LBA is much less than 112 or duration near 230, the vacuum will be very low.
Old May 18, 2003 | 08:24 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
cam is 208/221 LSA 112
Old May 19, 2003 | 09:18 PM
The Man's Avatar
running bad
have you checked to make sure you don't have vacuum runnning straight to the EGR? Is the EGR stuck open some?
Old May 20, 2003 | 08:38 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
There is no EGR on the Stealth Ram.
Old May 21, 2003 | 06:30 PM
1991 Z-28's Avatar
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
ttt
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
mizz0313
Aug 12, 2015 06:45 AM
djmarch
Aug 9, 2015 05:27 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
