Fuel Pressure Drops Quick
Old May 15, 2003 | 02:54 PM
blue86z28's Avatar
The fuel pressure on my 1986 CamaroZ28 TPI 305 is good and fine while running, but if you turn the car off the pressure drops at about 2/psi a second. Like if you came back in 1 minute it would be down to zero. does this mean there is a leak some where or my afpr is leaking or is this normal?
thanks,
Blue
Old May 15, 2003 | 04:54 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Sounds like one or all the injectors are leaking.
Old May 15, 2003 | 08:07 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
fuel pump check valve not working. or an injector leak. to figure out which one do this. have a gauge hooked up. while running, have someone clamp the feed line off at the rubber part. as soon as they get it clamped, shut the car off. it the pressure stays, then check valve. it it goes down still, then injector. thats how i figured out mine. now i just need to get another pump.
Infested
May 22, 2018 11:56 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
