occasional start-up smoke and rough idle help!
Old May 18, 2003 | 11:51 AM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
hey guys, about 1 out every 5 times i'll get the white puff of smoke which i had read could be valve seals (been doing that since since i bought it tho), BUT this last week the idle became rough and seems to be choking, even died once, thankfully started right back up. i've been having to keep it at 800-1000rpms at stops just to make sure it doesn't die again.
what could it be? fuel injectors? i know the fuel filter is ready to go.
i won't have time to work on it till next weekend and i'm worried it will conk out on me while driving to work! -=/
any tips and suggestions appreciated!
Old May 19, 2003 | 12:32 AM
Car: '89 GTA
eh?
Old May 19, 2003 | 02:00 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Mine smokes a little & idles roughly for a minute or two after sitting over night. My fuel filter is fresh, it has a fairly new fuel pump, clean fuel system, new ignition components... I haven't heard of bad valve seals or head gaskets causing rough idle, so I don't know either. Just had some related info.
Old May 19, 2003 | 06:58 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
I had the same problem on my 87 GTA, I relplaced my IAC and fixed the problem. I don't think you will have to worry about it putting you down though.
eightsixseven
Dec 16, 2024 01:50 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
JHX
Aug 29, 2015 02:30 PM
