Idle too high
Old May 19, 2003 | 12:52 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Idle too high
I put on a new manifold gasket yesterday and adjusted the fuel pressure. Now the idle is too high it is 1000 when it is usually 750 amd the adjustment screw is all the way out. The timing could be off a bit but it seems to run good. Is there any other way to adjust the idle speed?
Old May 20, 2003 | 11:12 AM
f0rmula350's Avatar
tps sensor, is your iac clean and working right?
Old May 20, 2003 | 03:26 PM
87IROC350HO's Avatar
Check out the "technicle articles" section and follow instruction on IAC and idle adjustments....
Stan
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
