Opinions/Suggestions on my setup
Old May 20, 2003 | 12:19 AM
danzig27's Avatar
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
I've started building a 383. 90 block. 10:1 4340 eagle crank, 6" lightweight 4340 eagle 3d h-beam rods, je pistons, superram base, plenum, runners, AFR190 heads, 58mm TB, 36lbs injectors, Holley AFPR, Holley 255lph fuel pump, 700r4, 3.73 posi.
I'm going to have a custom ground cam, I'm going to give him the specs of the LPE219, and tell him to stay somewhat close to that only more tailored to my combo.
As far as tuning, i'm going to have Cerra Racing in Illinois dyno tune the car. I don't want to worry about alot of the tuning. Eventually plan to run a 150 shot of nitrous. But we'll see how far down the road that will take me. Please give me any suggestions or opinions. Do you like it or not like it, what would you do to change it? Thanks!
Old May 21, 2003 | 12:40 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I don't think any opinions are necessary...it is a proven combo...go with it.
Good luck...
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
