VSS Question
Old May 20, 2003 | 01:49 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
VSS Question
ok I have a 86 TPI 305 MAF. I did an auto to manual swap on it.I put in an 84 T-5 then a tremec 3550, car has the cable driven speedo. Ok now for the problem, I am getting Error Code:24 VSS circuit error. I didn't put a VSS in the new tranny as I didn't thik there was one as the 84 didn't have one and it never tripped the code. Can someone tell me what is going on?
Old May 20, 2003 | 04:26 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
You had no VSS at all on your old auto trans? I know you said you have the cable driven speedo, but the VSS has a few other functions that the computer uses it for.
When I swapped to an auto from manual, I would get a code only when I really got on it. THen the car would run badly until I restarted it. I did not want install a new speedo cause my orginal was electric and my TH-350 would not accept the VSS I used a VSS from Jags that Run to fix my problem...
Old May 20, 2003 | 05:15 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
On an 86, the VSS is in the speedo. If the speedo works, then the VSS or wiring is bad.
Old May 20, 2003 | 05:18 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Thanks a million.. that is what I was thinking since I read up and notice some people talking about "in the speedo" but I Wasn't sure if it was on the actual device or just people refering to the whole get-up (cable, drive, gear) as the speedo.
Old May 20, 2003 | 06:11 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Good to know.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
