Header install question
Old May 25, 2003 | 11:48 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Just got finished installing some SLP headers (took about 9 hours) and when I took it out for the test drive, it was idling really rough like it had a huge cam in it and also it felt like it didn't have power brakes. Had to put the ****er to the floor to get it to stop. Checked for pinched lines and would cause. Thought it might be a vacuum leak but not for sure. Any suggestions would be great.
Old May 28, 2003 | 11:36 AM
383 rocket bird's Avatar
Have you checked to see if the vacuum hose from the plenum to the brake booster is in place?
Old May 28, 2003 | 12:29 PM
Morley's Avatar
Bingo! My most forgotten line to replace.
Old May 28, 2003 | 01:51 PM
Same here and the funny part is that as far as vacuum lines go that one is huge.
Old May 29, 2003 | 02:06 AM
Morley's Avatar
Yeah, but it is in the way of so many things that you are always pulling it back off for something, then forget to put it back once you finally get to what you were after.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
drathaar907
Aug 6, 2015 04:20 PM
