Fuel pump relay Help
Old May 26, 2003 | 02:49 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
I just applyed power to the G terminal of the aldl port The fuel did not give pressure but the relay was making a clicking sound every time I applyed power. Do I have a Bad realy or fuel pump? I have an 86 Chevy camaro Iroc-z 305 tpi... Thanks
Old May 26, 2003 | 02:55 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
sounds like the the pump might be bad, you can try to get a new relay but its a long shot, if u can hear the relay engage and disengage most likely its working right :-(
Old May 26, 2003 | 03:28 PM
Vader's Avatar
CC,
Back-feeding power to the fuel pump through the ALDL should not operate the relay. If the relay is "clicking" during this exercise, you may have a faulty one. Power DOES have to route through the NC contact of the relay, so the relay and its wiring needs to be intact for this test to work:
I'd suggest testing for voltage at the tank connector or relay socket wiring before condemning the pump.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
