tpi roc no more......LT1
Old May 27, 2003 | 10:15 AM
tpi_roc's Avatar
Well the LT1 intake is in and running, Had 3 days of fun with it before it nuked my tranny, go figure
Guess that means its making more power? Just thought I'd throw out another LT1 success story.
Old May 27, 2003 | 10:18 AM
f0rmula350's Avatar
sweet deal, i want a lt1 intake, but then agian i want the stealth ram. i dont know what i want.lol
Old May 27, 2003 | 10:31 AM
tpi_roc's Avatar
I wanted something easy to install, and that made some power, I got one of my wishes
After sorting out and tweaking a few things, the LT1 intake came off/on quick and easy. At first I didn't know what to think of the power, after a while It started to settle and just when I started to have some fun my slush box crapped out, no more automatics for me, the next one is a WC T5, and then a T56 from there next year (bank account willing)
Old May 27, 2003 | 10:36 AM
tpi_roc's Avatar
Ignore some of the things you see in the engine bay, I'm still in the process of cleaning up and finishing the install.
Old May 27, 2003 | 10:52 AM
91blackgta's Avatar
where did you get the fuel lines?
Old May 27, 2003 | 10:53 AM
tpi_roc's Avatar
The lines are millicans
Old May 27, 2003 | 11:50 AM
need4speedb4c's Avatar
I am planning on doing the TPI for LT1 swap...Anyone have any dyno results?
-Mace
Old May 27, 2003 | 11:52 AM
tpi_roc's Avatar
Try a search for that one, if that fails then start your own thread, you'll have better luck than it being burried in this one.
Old May 27, 2003 | 02:44 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
is that the john millican lt1 intake?
haveyou had any problems with leakage?
Old May 27, 2003 | 03:02 PM
tpi_roc's Avatar
The only problem is my transmission bite'n it.
Old May 27, 2003 | 11:02 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
good job LT1_roc
howd your tranny break...didnt anyone ever tell you not to neutral slam?
Old May 27, 2003 | 11:05 PM
tpi_roc's Avatar
Lost 3rd and 4th clutches
toasty fluid, no go
T5 time, untill I can afford a T56
Old May 28, 2003 | 12:22 PM
ULTM8Z's Avatar
I just had my TH700R4 rebuilt. The guy put in a bunch 2003 Cadillac Escalade clutches, bands, etc. It runs like a top now. The whole job cost about $1800.
If you want to retain your automatic, you might want to look into this.
Old May 28, 2003 | 01:12 PM
tpi_roc's Avatar
Automatic never again
I've had my share, I'm done with them
WC T5 this year, T56 hopefuly next
a TH350 wouldn't be so bad, but with 3.73's on a daily driver OD is nice and important to me.
Old May 30, 2003 | 09:50 AM
KYL98's Avatar
Car: 1991 Z28
How do you get in touch with John Millican??? I just bought the Hot Cam kit, and I think the LT1 intake would work MUCH better than the stock TPI setup.....did you lose any driveability with the LT1 intake? any torque loss? Also, Ive heard about people having some leak issues with the intake....true? Looks great man......wish I could find some dyno numbers.....or would it be the same as the actual Lt1???
Old May 30, 2003 | 09:58 AM
tpi_roc's Avatar
Millicans site is www.lt1intake.com his email is listed there
also he is a board member here, he shows up occasionally and may even respond to this.
No it would not be the same power as the original LT1 due to MANY variables, compression, no distrib, different cam grinds, aluminum heads with different intake ports, yadda yadda..
The hotcam would be a perfect mate to the LT1 intake on a street car, If i had to guess I'd say there was no loss of torque but the curve DEFFINATLY got wider, and as for drivability, its MORE drivable than the TPI was, by far. Its a smooth strong electric power from stall all the way beyond 6,000 rpms.
Old May 31, 2003 | 05:39 PM
Ragtop89's Avatar
Congrats on the successful intake swap!
Bummer on losing the tranny!
You'll be happier with the T-5.
Check out Tremec's TKO T-5 - it can handle the power you're putting out and is an EASY install.
Old May 31, 2003 | 05:44 PM
tpi_roc's Avatar
Wish I could afford such things, but if i could it would be T56 anyways. SO for now stock WC T5 will have to do
But yea it'll be nice to get rid of the slush box
stalkier
Dec 6, 2015 11:25 PM
Papaginos
Sep 27, 2015 03:29 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
