Mx lift question
Old Jan 11, 2003 | 10:07 AM
Nasty_Bird_'90's Avatar
Mx lift question
What is the max lift that a stock iron head L98 can handle before threre are valve/piston clearance issues? I know the duration of the cam is an issue, but I just need a rough idea. I've got KB flat top pistons and iron heads that haven't been decked.
Old Jan 11, 2003 | 10:40 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
oops
Old Jan 11, 2003 | 10:41 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
oops sorry..
Old Jan 11, 2003 | 11:09 AM
xanax's Avatar
the stock retainers hit the valve guide at around .480 or somewhere close i believe.
Old Jan 11, 2003 | 01:31 PM
I'm looking for max lift before there are valve to piston clearance issues. How much lift can I have before the valves hit the pistons? I've already had the guides cut down enough so the heads will handle .550". Before I had them machined, the stock heads would only handle .435" before the stock retainers hit the guides. So all the stuff I've heard about the stock heads handling .480 is a bunch of .
Old Jan 11, 2003 | 05:27 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Does an L03 head count ?
I installed a cam with these specs using stock L03 heads on a TBI 305:
217/225 @ .050, .475/.480 lift 109 LCA.
I was using Comp Cams Magnum rockers with 1.6 ratio so my overall lift was in the low .500s. That was on stock springs and after about 2000 trouble free miles I installed Comp Cams conical springs and locks and retainers -- supposedly good for .550 lift.
I never noticed any difference after installing the new springs I just put them in because the guy at the local speed shop was freaking on me running that much lift with stock springs.
adious,
RP.
Old May 31, 2003 | 08:13 PM
trigger GTA's Avatar
Car: 92 TA vert
Nasty_Bird_'90 did you ever find the min clearance needed? i needed to know the same thing
Old May 31, 2003 | 08:40 PM
Z91Z's Avatar
I ran a ZZ4 cam in an 88 l98 IROC , no problems for 10,000 miles . Engine and heads were totally stock . Intake lift is .510 . I don't know if this helps you . Probably not .
beastin91rs
Oct 9, 2015 07:38 AM
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
