code 33
Old May 28, 2003 | 07:54 PM
screwowmer's Avatar
code 33
I just put an 87 tpi into my s10 I used the painless harness and I've been getting the code 33 al the time it idles like crap when it idles, and it always seems to be running rich please help!
Old May 28, 2003 | 08:24 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
With a code 33 the car will idle like crap, experience there. Anyway, theres a series of troubleshooting that you can do that you can go through to find the problem. You can do a search for it on this board, it comes up from time to time. Are the relays new? Is the MAF new?
Old May 28, 2003 | 10:46 PM
screwowmer's Avatar
relays are all new the maf has the screens removed but it was like that in the car and ran fine with no codes.
Old May 28, 2003 | 10:54 PM
Car: 86 Cutlass
I've used this before, found the MAF to be bad.
Code 33 / 34 tests.
First check air ducts for cracks, holes and tighten clamps.
With the ignition off, unplug the MAF and apply power to ALDL terminal
"G". Check the red wire on the MAF connector for power. If no power,
verify 12v on relay connector orange and white/tan wires. Verify the
connector black/white wire is grounded. Verify black wire from MAF
connector terminal B to ECM connector A11 with an ohm meter. Verify
red wire from relay connector to MAF connector with an ohm meter.
If all is good replace MAF power relay.
Turn ignition on, Check MAF connector dark blue wire for 12v, if so,
unplug MAF burn off relay and check again. If so, check relay
connector black wire for ground. If so, the black wire is shorted to
ground or the ECM is bad. If not, replace MAF burn off relay.
If the dark blue wire at the start of the above test had no voltage,
check the MAF connector dark green wire with ignition on for a 5v
reference signal. If so, and all connectors are good, replace MAF.
If no 5v reference on dark green wire, verify it from the MAF connector
to ECM connector B12 with an ohm meter. If the wire is good replace the
ECM. If the dark green wire has 12v on it, turn ignition off and unplug
the ECM connectors. Turn ignition back on and check again, if so,
it is shorted to power somewhere. If not, and all connectors and
grounds are good replace ECM.
Old May 28, 2003 | 10:57 PM
screwowmer's Avatar
Thanxz i'll try that this weekend and report back
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
