Idle is high what do I look at
Old May 29, 2003 | 11:50 PM
biff85ta's Avatar
Car: 04 Vette
I purchase an 85 tpi car yesterday and it had all kinds of vacuum leaks when I got it home which I fixed but the idle is still way high like 1500 rpm I ran the trouble codes and got a 22 which is the tps could this be my problem?
Old May 30, 2003 | 08:57 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Yes your TPS can most definatley be your problem. But it is not just a replacement part. You have to replace it, then set it correctly.
To do this you need two wires and a voltmeter. I prefer digitial for this but I suppose analog could do in a pinch. There is a proceedure on this here https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Hope this helps.
Old May 30, 2003 | 10:00 AM
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
Re: Idle is high what do I look at
Did you set the Idle Air Control and the Throttle Position Sensor voltage?
Old May 30, 2003 | 03:02 PM
biff85ta's Avatar
Car: 04 Vette
Noy yet but they will be first on my list as I am trying to get one ready to sell and the other ready to drive plus work I have more to do than time.
Old May 31, 2003 | 09:55 PM
biff85ta's Avatar
Car: 04 Vette
I have set the iac but the tps is shot so off to the parts store in the morning I go no matter how I adjusted the tps the most I got was .3 something so it must be shot.
Old May 31, 2003 | 10:32 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Are you sure you were on the center wire in the plug. At .3 volts the engine should not even run, surely not at 1500 RPM's
Old Jun 1, 2003 | 12:40 AM
biff85ta's Avatar
Car: 04 Vette
Yeah I was on the center terminal I could run it up and down and vary the readings ti just would not adjust far enough to set at .54 going to buy a new one in the morning and probably a new IAC as I believe it must be bad as well.
Old Jun 1, 2003 | 12:26 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
First check that the gray wire on the TPS plug has 5 volts with the ignition on and the blk wire is at ground (0 volts) the center (signal wire) should have a blue tracer.
Old Jun 1, 2003 | 04:03 PM
biff85ta's Avatar
Car: 04 Vette
It was the tps changed now its all good.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
