finding a code...........
Old May 31, 2003 | 12:59 PM
duke a's Avatar
my car is thowing a code, and i heard from someone that there is a way to find the code on the cars. he said something to the affect of turning the key off and on like 4 times, the the ses light will flash say 2 times then like 3 times so then you have a 23 code. is this true???? or how exactly do you do this.
Old May 31, 2003 | 01:14 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Duke turn the key on.... the SES light should flash you the code 12.... 3 times telling you that the system is working properly. Then it will flash any other codes telling you if you have any other problems. You need to loop circuits A and B at the diagnostic terminal under the dash for this to work though.
Old May 31, 2003 | 01:33 PM
duke a's Avatar
does anyone have a pinout of the port so i know which ones are a and b????
Old May 31, 2003 | 01:52 PM
Car: 92'Camaro RS
Engine: a loud one
It's the open diagnostic plug under the dash on the drivers side.... A and B should be the top two ports on the right hand side of the plug.
Old May 31, 2003 | 01:54 PM
Car: 92'Camaro RS
Engine: a loud one
this might help.......http://www.chevythunder.com/fuel%20i...g%20A.htm#list of troublecodes
Old May 31, 2003 | 01:59 PM
duke a's Avatar
thanks man
ChristinaMarie
Sep 11, 2015 06:28 PM
NiG
Sep 7, 2015 11:25 PM
Street Lethal
Sep 7, 2015 01:09 PM
