Low voltage, once drops doesn't come back up...
Old Jun 2, 2003 | 09:54 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Alright, for all you search flamers out there:
I did a search and everyone was looking at the stock voltage gauge inside the car, and it didn't quite match my problem...
My car will run at about 13.5v13.8-v right at startup, it stays about the same the whole time. Once warmed up, it drops to high 12v. Once it hits 195* (where my chip turns both fans on), the voltage dips, and used to return. Now it just stays at very low 12v when at a light, but returns to 13v under throttle. Even when the fans turn off at 185*, it stays that low.
Tonight I was just cruising, atmospheric temp was mid-80s, and high humidity. The car was running at 178* and still was that low of voltage. Alternator is new, got it last November. Battery reads 12.5-12.9 depending on the day and heat.
The mods are in the list, and I have a gauge that uses a relay from the key. The relay connects the voltage gauge directly to the battery.
What should I look at now?
TIA
Old Jun 3, 2003 | 12:31 PM
ttt
jharrison5
Aug 19, 2015 05:53 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
mizz0313
Aug 12, 2015 06:45 AM
BOOT77
Aug 10, 2015 12:20 PM
