C5 Injectors
Old Jun 4, 2003 | 11:31 AM
kevosiroc's Avatar
Corvette C5 Injectors
Does anyone know if the C5 injectors will fit a TPI wiring harness, and will they work OK? I thought I heard that they use different connectors or something?
Anyone know?
Old Jun 4, 2003 | 12:11 PM
tpi_roc's Avatar
To my knowledge if the C5 wasn't a Z06 or an LS4, and was just the standard LS1 its the same LS1 that the Fbody got, in which case the injectors work with TPI, however are a little shorter, and i think the resistance (or something?) was just a HAIR different which could possibly result in a slightly different fuel curve...
I know the information has been around, try a search.
Old Jun 4, 2003 | 03:56 PM
kevosiroc's Avatar
Anyone know about difference of resistance and/or if it needs to be dealt with (and how)?
Old Jun 4, 2003 | 04:15 PM
tpi_roc's Avatar
search
Old Jun 4, 2003 | 04:59 PM
tpi_roc's Avatar
Originally posted by Ringmaster72
Well, fellows, I went ahead and got the facts from Rich at Cruzin Performance. He was nice enough to lay it all out. Here is the email he sent me.
Hi Tim,
Yes, you can use LT1 injectors as replacements for your car.
LT1 injectors have a slightly lower resistance than the original injectors
that would have come in your car but they are still "high impedance"
injectors (or are sometimres referred to as a "saturated" injector).
The original injectors in your car would have a resistance of approximately
15 ohms and the LT1's will be around 12 ohms.
A "true" low impedance injector (also sometimes referred to as a "peak and
hold" injector) has a resistance of approximately 2 ohms and cannot be used
as a replacement for a high impedance injector without damaging the injector
drivers in the ECU.
Hope this answers your question. Sometimes there is a lot of mis-information
spread on the various message boards. I'm glad you took the time to ask.
Better to be "safe than sorry".
Rich J.
Old Jun 4, 2003 | 05:22 PM
kevosiroc's Avatar
is that in referencce to switching from LS1 injectors to LT1 injectors? Or from TPI to LT1?
I would be switching from TPI to LS1.
Old Jun 4, 2003 | 05:24 PM
tpi_roc's Avatar
its tpi to lt1
Do a search
they're also rated at a different fuel pressure than what TPI injectors are, so they wont flow what you expect
Old Jun 8, 2003 | 10:11 PM
billyhoss's Avatar
lt1 psi
what is the psi that the lt1`s run at, the tpi`s are rated at 43.5 and i want to say the lt1`s are rated at 39, iam i right and if so then does that mean that they are 24 pounds at 39 psi?
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
