tried to adjust my idle speed
Old Jun 4, 2003 | 02:26 PM
duke a's Avatar
i followed the tech article on it step by step. my car will not stay cracked after i unplug the iac and try to adjust it. it will stay cranked as long as i give it gas, but after that it will die. is there something that i am missing????
Old Jun 4, 2003 | 03:17 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I had an idle problem when I did this "mass air screens removed". Is this mod on the car with the idle problem?
Old Jun 4, 2003 | 03:29 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I am having this same problem with mine right now. Vader suggested letting the car heat up to normal operating temp. I haven't tried it yet. Good luck getting answers. I posted this same question a couple of weeks ago and didn't get much help other than Vader's suggestion.
Old Jun 4, 2003 | 03:37 PM
duke a's Avatar
thanks guys, i really cant remember about the screens. i removed them when i first got the car. i dont even know where they are. i prolly throwed them away. oh well. its not real bad. it idles at about 1100 rpms and when you put it in gear it goes back down to abotu 700
Old Jun 4, 2003 | 05:58 PM
Vader's Avatar
Throttle Minimum Air Position
Tools needed:
1. Torx driver # T-20
2. Paper Clip
3. Small Punch
4. Tachometer
GENERAL NOTE: The engine should be at normal operating temperature before performing any adjustments. Never rely on the dash mounted instruments for diagnostics and adjustments. The oil pressure and temperature gauges and the voltmeter and tachometer just aren't calibrated accurately enough for diagnosis, but are a relative indication for monitoring the vehicle while driving.
For this adjustment, the transmission will be in DRIVE while you're under the hood. You will need to securely set the parking brake and block the drive wheels. It would also be a good idea to have an assistant hold the service brake while you perform the adjustments.
In order to successfully complete the adjustment, the IAC air passages and pintle need to be clean. The throttle plates and bores need to be clean as well. If this is not the case, you'll need to remove the air cleaner from TBI engines or the intake air bellows from TPI engines to gain access to the area to be cleaned. A spray-type carburetor cleaner works well for this. Cleaning the IAC passages on a TPI/MAF engine will set a DTC, but we'll be clearing that later. With the engine idling, direct the spray cleaner in to the IAC air passages and around the throttle plates. Shut off the engine and continue cleaning the throttle plates by opening the throttle manually. Once everything is satisfactorily cleaned, replace the air bellows on TPI engines. Many times, this alone can solve IAC/idle speed problems.
If this doesn't solve the problem, you may need to remove and clean the IAC stepper motor. If the IAC appears to be clean and functioning properly, continue with the adjustment procedure.
Idle Air Control Cleaning
You can remove the IAC and service it. Remove the electrical connector from the IAC. Unscrew the IAC unit from the throttle body.
You can gently rock the pintle back and forth and allow the spring to extend it until it comes apart in your hands. Clean everything with lint-free cloths and a mild solvent. Harsh solvents can affect the insulation of the stepper motor coils. It's generally the dirt and buildup on this worm shaft that causes sluggish IAC operation.
When the worm gear on the pintle shaft is clean and dry, apply one drop of clean light oil to the shaft and work the pintle back into the rack gears of the motor by the same rocking motion. It takes a while to get the pintle back into the worm gears, but you'll get it. It is important to get the pintle fully retracted into the housing so that the pintle is not forced against the gears when reinstalling the IAC unit in the throttle body.
While the IAC is out, clean the air passages in the throttle body. The orifice in the TB where the IAC resides is the seat that the IAC valve closes against, and it can accumulate a lot of carbon, dirt, and debris. The easy way to do this is with carburetor cleaner and a small stiff brush.
When everything is clean and dry, replace the gasket if it is damaged, apply a little anti-seize to the threads, and torque the IAC to the proper specs. (13 ft/lb for '85-'89 , 30 in/lb for 1990-on.) Proceed with setting the TPS and minimum air position.
Locate the ALDL connector under your dash panel, in the driver's footwell area. Remove the plastic trim cover (if it is still there).
Cut and form a paper clip into a "U" shape. Insert the clip ends into the ALDL in the 'A' and 'B' sockets.
Turn on the ignition, but don't start the engine. This will force the ECM into its diagnostic mode. Wait 30 seconds to allow the IAC pintle to fully extend. Under the hood, remove the electrical connector from the IAC, then turn off the ignition and remove the paper clip jumper from the ALDL. With the IAC pintle fully extended (closed) all idle air will be controlled by the position of the throttle plates. Some manuals indicate that the EST bypass connector should be disconnected for this procedure, while some make no mention of it. While timing is a factor in idle speed, the EST should only operate as a function of engine RPM, temperature, and detonation sensor inputs. To remove all doubt, disconnect the EST bypass connector is your car is so equipped. Some TBI and V-6 engines do not have this bypass connector, and therefore must be set with no regard to the EST system. The EST can be bypassed on some cars by grounding the diagnostic terminal at the ALDL and continuing with the procedure, but the fuel mixture will be skewed to the rich side, affecting idle speed as well. In any event, the minimum air position idle speed range is wide enough to allow for some variations. As always, it is best to consult your service manual for the exact procedure for your system.
Locate the Torx screw on the left side of the throttle body. It may be equipped with a protective metal cap from the factory. This was intended to discourage adjustment. If the cap is present, use a small punch to knock it out. Once the screw is accessible, start the engine and place the transmission in DRIVE. Adjust the throttle stop to obtain 400 RPM with the transmission in "DRIVE" on an automatic transmission car, 450 in neutral on a manual transmission car, rotating the Torx screw clockwise to raise speed and counter-clockwise to lower speed. Once the idle RPM is set, place the transmission in PARK and turn off the engine.
Re-connect the electrical connector onto the IAC. Start engine. Idle speed should be governed by the ECM at approximately 600-650 rpm in "DRIVE" (for unmodified cars). Idle speed in NEUTRAL or PARK is less significant, and will be higher.
Throttle Position Sensor (TPS)
Tools needed:
1. Digital Volt-Ohm-Meter (VOM)
2. Breakout jumper wires or probes (make your own)
3. AutoXray, Diacom, or similar scanner will replace the VOM and jumper wires.
Turn on ignition, but don't start the engine.
With a diagnostic scanner: plug in the scanner and read the TPS voltage. It should be 0.54Volts +/- 0.07 VDC.
Connect the VOM to the TPS electrical connector terminals ‘A' and ‘B'.
With a breakout jumper: Disconnect the electrical connector from the TPS. Install the breakout in-line, between the TPS and wiring harness connector. Connect the meter probes to terminals 'A' and 'B' on the connector. (‘B' is the positive connection, ‘A' the signal ground, or negative.)
With probes: If you have very slender probes on your VOM, you can back-probe the TPS connector while it is attached to the TPS. If you have made probes of large dressmakers pins or a similar item, you can back-probe the connector as well. Connect the meter probes to terminals 'A' and 'B' on the connector.
Turn on the ignition to read the TPS output voltage at the idle position. The reading should be 0.54VDC +/- 0.07VDC. The ideal is the center of the range, 0.54VDC for a stock engine. To adjust the output voltage, loosen the two Torx screws holding the TPS to the throttle body, and slightly rotate the TPS up or down, reading the voltage until it comes into specification. Tighten screws. Using the throttle lever, rotate the throttle to WOT (wide open throttle). The TPS voltage should be over 4.0 volts. Close the throttle again, and then slowly open it to WOT, observing the voltage reading. It should increase progressively and in a linear fashion. If it sticks or jumps or falls off at all while doing this check, the TPS sensor may be failing and could be a cause of stumbling and driveability problems.
After achieving the desired setting, turn off the ignition switch. Remove all jumpers or the scanner and reconnect the TPS connector as required.
Reinitializing the ECM
If you set a DTC during the procedure, the SES light should be illuminated on the dash. This ECM retains DTC data for the previous 50 engine starts, so the codes will eventually be cleared. If you want more immediate results, after shutting down the engine disconnect the negative battery terminal for five minutes. This will clear the ECM of all diagnostic trouble codes. Clearing the ECM also clears any data learned about your engine, and clears the radio presets. If you have a Delco-Loc or Theft Loc II radio, make sure you follow the procedure to unlock the radio protection before disconnecting the battery. This five minutes is also just about long enough to clean both battery cables. Reconnect the battery. When you first start the engine after clearing the ECM, the engine will operate with base parameters programmed into the ECM PROM. These parameters may not be optimum for your engine, but the ECM will enter a Block Learn Mode soon after the engine is warm and enters Closed Loop Mode. The ECM will write new data tables specific to your engine and will eventually rely on those tables instead of the base tables of the factory program. You can expedite this process by driving the car for 20 minutes under varying conditions to allow the ECM to initialize. Or you can wait and drive the car normally at your convenience. The BLM tables are constantly being updated as sensor input ranges change, but the greatest change will occur within the first twenty minutes of Closed Loop operation.
Old Jun 7, 2003 | 02:42 PM
duke a's Avatar
alright, my car was at normal operating temp. it still falls on its face with the iac unplugged. i will stay cranked as long as you give it gas, but then nothing. what am i doing wrong?????
Old Jun 7, 2003 | 08:07 PM
Stevie's Avatar
Turn in the little torx screw, which sorta appears like a standard idle adjust on a carb, until it will idle using the procedure above. Then follow the procedure.
good luck
Steve
Old Jun 7, 2003 | 09:13 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
How much gas would ya say you need to give it to stay lit? Just a hair right. If so try and open up the throttle plate a tad and see what happens. Also don't neglect to clean those passages like Vader suggested. If the IAC passage is clogged, then it has no air to add to idle.
Old Jun 7, 2003 | 10:40 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
I guarentee that your MAF sensor is bad. Try removing it from the air cleaner part only (dual snorkel) and have everything plugged in after that. then have a buddy start your car and the second the car starts put your hand over the MAF so tha only a little bit of air is able to pass right through. This should make your car run just fine, or at least let run and idle. I just had this problem not even a week ago and I had the same exact problem. So just give it a try and see what it does. If it runs your MAF is bad or if it does run something else is wrong. Give that a try before tearing apart you IAC...
Jason
Old Jun 7, 2003 | 10:56 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Jason
This kind of makes sense because my car is doing the same thing along with rough idle and I got a code 34 the other day and the car dies at redlights. These are symptoms of a bad MAF. I am going to try this.
Old Jun 8, 2003 | 06:00 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Okay, I tried it. Whenever I cover the opening to the MAF the car stalls out. I'm covering about 75% of the opening. What does this mean? Is the MAF good?
Old Jun 8, 2003 | 08:11 PM
Stevie's Avatar
Sorry, guys but I still think your minimum air adjustment (the little torx) is set way too low. Crank it up and see if you can then complete the procedure as outlined before. Do you have a scanner? If so, then take a look at the steps on the IAC. I'd think you should see something in the 30's or 40's.
Steve
Old Jun 8, 2003 | 09:53 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Do you have to disconnect the EST wire when setting minimum idle?
Old Jun 9, 2003 | 11:57 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I did what Stevie recommended and the car stayed running. I was able to set the idle. Right now when I crank the car the RPM's go up to 1500 and slowly works it's back down to about 900.
Old Jun 10, 2003 | 08:42 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Good, so its all fixed for now, right? Happy motoring...
Old Jun 10, 2003 | 09:03 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
It seems to be. I haven't driven it much since adjusting it so I haven't tested it to make sure it doesn't die at the light.
Old Jun 13, 2003 | 08:21 PM
Stevie's Avatar
That idle flare-up on start seems to be standard with the factory software on the chip. Mine does the same thing and I'm working on the programming to get it slowed down a bit.
Good Luck
Steve
specialized
Jun 18, 2022 09:26 AM
86IROC112
Aug 21, 2015 07:20 PM
ezobens
Aug 19, 2015 10:29 PM
perZ
Aug 15, 2015 01:17 PM
