installed Hooker super comps.. need a little help
Old Jun 4, 2003 | 05:56 PM
prockbp's Avatar
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
i had my super comps installed this week... and the engine appears to be running very strong, the engine revs up extremely fast compared to the old manifolds.... so, i'm sure i got some horespower gains and the torque felt fine...
but.... i haven't been able to actually make a wot run because the freaking brake vacuum assist has been disconnected and i guess the hose is still at the shop...
to the point of this post--
the mechanic broke off some kind of switch or sensor of some sort and the local chevy dealer had no idea what part it is.....
this sensor/switch is located right below my passenger side header flange between the #6 and #8 cylinder... the part of it that is still connected is made of brass and it's about the same diameter as a quarter(25cents)
car is an '89 IROC with a 5speed tranny... person i bought it from said it had a 350 switched into it in place of the 305(i dunno if i believe that or not, but that may be a clue as to what this part is)
anybody have a clue what this is?
thx for the help
Old Jun 4, 2003 | 07:40 PM
kevinc's Avatar
Car: 1982 Z28
Sounds like that's your auxiliary fan switch. It's a thermostatically-controlled switch that closes at a given temperature, switching the aux fan relay and powering the fan.
Cheap part, easy to replace (even without draining the coolant if you're fast) and definitely not something you want to do without during Summer weather.
You can make things better for yourself by using one for a 1987 Buick Regal VIN 7...on temp is ~203degF versus 220+ for the Camaro piece. Direct fit, no mods needed.
Old Jun 9, 2003 | 11:18 PM
prockbp's Avatar
Car: 1989 IROC-Z
thx for the help Kevin.... there are 2 switches right? are they for seperate fans? or do they both need to be working
i'm having a tough time finding the right switch.. nobody has a clue what i'm talking about when i tell them what i need... so think i'm going to take your idea and get that buick regal switch
Old Jun 10, 2003 | 10:38 AM
kevinc's Avatar
Car: 1982 Z28
The ECM controls the primary fan, using the Coolant Temp Sensor input. The secondary fan is controlled by the switch we're discussing.
Coolant Temp Sensor is on the front of your intake if it's a TPI engine, 2-pin plastic connector near the coolant output nipple, both face toward the radiator.
Old Jun 10, 2003 | 12:54 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
he's right it's the fan switch located between the #6 + #8 plugs.
tell the parts guy you need a radiator fan switch. that's the part they are listed under.
not trying jack the post but which fan switch sensor is used to turn the fan on around 212*?????
thanks
Old Jun 10, 2003 | 08:32 PM
prockbp's Avatar
Car: 1989 IROC-Z
thanks guys, that was very informative
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
makaveli09
Aug 12, 2015 09:07 PM
