42lb SVO fuel injectors needed?
Old Jun 5, 2003 | 08:18 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have a 406 with a miniram and currently am running 36lb SVO injectors. I just finished rebuilding the motor and am installing it now and was wondering about the amount of fuel that will be needed.
The motor is 406, 11.5:1 AFR 210 heads, miniram, solid roller cam 248/248 @ 0.050" with .615/.615 lift on a 110 lsa. TPIS estimated HP at 530-560 at the crank.
Car has a 700r4 with 3200 stall, 4.11 gears, hooker super comps into 4" Mufflex, DFI, etc.
When I did the calculation for the injectors i got
560 HP * .55 (efficiency number from Accel) = 308 / 8 cylinders
= 38.5 / .85 (for duty cycle) = 45.29lb/hr injectors
HOWEVER, Ford rates their injectors at 39.5psi and I am running at 47-48.
This means that a 36lb SVO injector at 48 psi is really putting out 42 lbs. right?
Do I have this right? I know the only real way is to put it on a dyno but I am hoping someone here knows a little more about this than I do.
Thanks guys
Old Jun 5, 2003 | 01:14 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
This article from Holley explains it pretty well.
http://www.holley.com/HiOctn/TechSer...l/Artcl07.html
Old Jun 5, 2003 | 01:57 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
That article is cool...I would say keep your current injectors and consider raising the FP a bit if you need to. No sense in buying a set of larger injectors...unless you really want to...
There are people who run FP at 50-60 psi to help deliver more flow and there is usually little downside to doing this...maybe a rougher idle (until you tune it properly)...
Old Jun 8, 2003 | 07:01 AM
LD85's Avatar
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
36# is ample I think, I have almost the exact set up as yours and use 24# with no problems. But I only have 500HP
bryan623
Mar 22, 2021 06:43 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kyleb24
Aug 15, 2015 08:24 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
