Stealth Ram fuel rails
Old Jun 5, 2003 | 03:08 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Im not so sure the stock fuel rails would work right on a Stealth Ram. Has anyone tried or even seen a way you can make your own fuel rails to fit this. Or even modified the stock fuel rail to fit. Ive seen custom made fuel rails and seems like a rather simple project. Ive read the post about not useing the stock rails in the Stealth ram sticky post but he just answers no to stock rails. Im wondering if you could plumb your own rails. Ive seen they sell the aluminum stock for the fuel rails undrilled. Seems like you could make fuel rails cheaper than buying the stealth ram rails and save $100.
Old Jun 5, 2003 | 05:42 PM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
time + materials = not worth it in my book
JMO
Old Jun 5, 2003 | 06:11 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
JMO
I'm w/ poorboy on this one. We've both done the swap from TPI to the HSR. I know its hard sometimes, but try and save up for the kit from holley.
Old Jun 5, 2003 | 06:54 PM
BOTTLEDZ28's Avatar
Transmission: A4
ditto that. Just buy the HSR rails and sace yourself a headache.
Old Jun 5, 2003 | 07:06 PM
shaggy56's Avatar
Car: 71 Nova
I have alot of machineing experience and plumbing experience. I honestly dont see it as a difficult task.
Old Jun 5, 2003 | 07:08 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
fuel rails aren't far enough apart. then the regulator would interfere with the manifold itself. that's why they put the regulator off the end of the driver's rail.
Old Jun 6, 2003 | 05:54 AM
poorboy8's Avatar
Car: 79 Camaro RS
Transmission: TH350
Well then bang a set out man And if they work then you have a nice custom set of fuel rails!
9192camaro
16
Feb 3, 2019 12:21 AM
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
