Adjustable fuel Press. Regulator??
Old Jun 5, 2003 | 09:38 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I picked up a spare TPI system awhile back, and it has a Adjustable FPR, but the weird thing is... It has no Vacum fitting for a Vac hose to hook up to it. It this normal? This isn't a home made jobby either, Will this cause any problems?? Or am I ok. Cause now that I installed it the car runs like a bag, it is set at 50psi. And it appears the injector on cylinder #2 is not working now, as the car is missing badly, and the header tube is not getting very hot, checked sprak it's there, so it has to be a fuel problem. Any suggestions or ideas??
Thanks,
Keiran
Old Jun 6, 2003 | 12:02 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Kaz, that's really not normal. Without a vac reference the injectors are getting max PSI all the time. I've heard of stock injectors failing when pushed past 50 psi, like mine did Maybe you could TIG a vac spout on there? If you can wait a few weeks you can have the AFPR i'm taking off my GTA. It's not perfect but it's cheap. Is this the TPI setup on the SS?
Old Jun 6, 2003 | 06:43 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Thanks Paul. Yeah this is on my SS. DANG!!! So that is why the one injector stopped working. Well I have a few weeks or more to wait now anyway so that I can afford new injectors. What do you need for the AFPR your taking off the GTA? I am going to need it. Thanks alot Paul!!! I appreciate it.
Thanks,
Keiran
MustangBeater20
Oct 29, 2022 09:20 PM
italiano67
Dec 11, 2016 09:21 AM
g.l.mos
Aug 22, 2015 12:02 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
