TPI guru's please need help??
Old Jun 10, 2003 | 11:22 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I have a 89 L98 that I have been having a problem with. #2 cylinder does not seem to be firing, I have tried new injectors and a new ECM and Prom. I have great spark, and have time and time again checked the valve lash. I have come to the conclusion that it is not the injector nor spark, nor the vavle lash, the injector is pulsing as I can feel it just as much as the other injectors. Could this be a bad ground issue, or am I totally over looking something?? Any thoughts or guidance would be greatly appreciated.
Thansks,
Keiran
Old Jun 10, 2003 | 11:28 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Spark plug? Wire? Cap/rotor? How did you determine you have good spark?
Old Jun 10, 2003 | 11:31 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
I pulled #2 wire and put a brand new spare plug in it. Nice strong consistant spark, new cap and rotor too. Any other ideas?? Oh and new plugs too.
Thanks.
Old Jun 10, 2003 | 11:44 AM
Ricktpi's Avatar
A good spark out of the cylinder is one thing, however when compression pressure is applied its another. How did it run when you put in a new plug?
Old Jun 10, 2003 | 11:50 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Unfortuneatly the same with the new plugs.
Old Jun 10, 2003 | 12:55 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Back to the original stated problem... how did you determine that #2 wasn't firing?
Have you performed compression and leak down checks?
Old Jun 10, 2003 | 01:02 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
I can hold onto #2 header pipe without burnig my hand, I just did a compression test on #2 130psi
Old Jun 10, 2003 | 01:07 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
What does the #2 plug look like? Gas fouled? Just like new?
How do the others look?
Old Jun 10, 2003 | 01:25 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
The plug was badly fouled so I went and got another one, it didn't clear up right away so I gave the injector a good wack. Bam! it cleared up right away, and now there is no touching the header. I thank all of you for your input. I would have drove myself crzy with this one, but all is good in TPI land!
Thanks everyone!!! :hail:
Keiran...
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
formula_novice
Aug 18, 2015 08:48 PM
Sanjay
Aug 12, 2015 03:41 PM
