TPI Setup Help
Old Jun 12, 2003 | 03:40 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
TPI Setup Help
Hey all
I'm in the process of dropping an 88/89 TPI engine in my 87 Camaro and I'm having a bit of trouble with the wiring. I can figure out where most of the wires go, except for a couple... Here's some pics. Maybe someone can help?
the green connector seems to fit in that grey solenoid, but I'm not sure where the white one goes
Can't figure these ones out... I know that the 6 point connector doesn't go to the wiper motor (it's already connected)
Does the 89 TPI harness come in 2 sections? I can't seem to find the distributor wires & can only find one connector for the coil.
Old Jun 12, 2003 | 04:05 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
top picture is your air injection diverter valve wiring
Old Jun 12, 2003 | 04:07 PM
Jproz1167's Avatar
the bottom one almost looks like it's the headlight module plug for a firebird, could be wrong though
Old Jun 12, 2003 | 10:46 PM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
So I won't need to worry about those if I'm not using the smog pump then, right?
Old Jun 13, 2003 | 01:04 AM
rumpilstiltskin's Avatar
The lower picture goes to your distributer.
Old Jun 13, 2003 | 01:54 AM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Hrm, I must have the wrong Dist then... the connectors on the dist I have, look nothing like that.
Me thinks it's time to invest in the TPI Swappers Guide
Old Jun 13, 2003 | 02:20 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
When I did my TPI swap, I believe I used the distributor wires that were already on the car, I just changed the connector to match the small distributor. I am pretty sure that is what I did. It's been over a year and a half ago though.
The bottom picture looks a lot like the connector for ECM power, Fan Relay harness connector, and not sure what the white one is.
I just went outside and I couldn't find those 3 connectors
Old Jun 14, 2003 | 08:32 PM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Well I got it all figured out... I was missing a pair of wires that ran from the distributor to the coil.
Now all I need is to get my hands on a dual fan setup
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
