HSR Q - Part # for replacement plenum-base gaskets
Old Jun 13, 2003 | 01:49 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Where can I pickup some replacement gaskets for the plenum to base? Anyone know a part number?
Old Jun 15, 2003 | 08:21 AM
BOTTLEDZ28's Avatar
Transmission: A4
not sure on the part number but Jegs and or Sumit has them for a few dollars. Just tell them what you need
Old Jun 15, 2003 | 09:50 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
called silicone. but the plenum gaskets are for a weiand tunnel ram.
Old Jun 15, 2003 | 10:31 PM
David 91RS/Z28's Avatar
I believe Thunder Racing has them. They are a sponser of this board also!
Old Jun 16, 2003 | 04:33 PM
kevinc's Avatar
Car: 1982 Z28
Re: HSR Q - Part # for replacement plenum-base gaskets
Do you mean plenum to runners? If so, check the FelPro parts list at your local shop. 93160 is the upper set, comes with plenum to runner and runner to base gaskets as well as TB gasket. $15 at Advance Auto.
Old Jun 16, 2003 | 10:24 PM
mrr23's Avatar
Engine: 360 HSR
kevin - he's looking for gaskets for a Holley Stealth Ram.
Old Jun 17, 2003 | 03:22 AM
kevinc's Avatar
Car: 1982 Z28
Whoops! Didn't catch that HSR in the subject line...
1992 Trans Am
May 10, 2023 07:19 PM
MY87LT
Aug 17, 2015 08:43 AM
mizz0313
Aug 12, 2015 06:45 AM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
